Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Van
Fuel System
Fuel Injector
Injectors not spraying
1995 CHEVROLET VAN
77,000 MILES • 5.7L • V8 • 2WD • AUTOMATIC
RICK J35
MEMBER
1 POST
Injectors not spraying, noid light not lighting when I try to crank.
Sep 1, 2018 at 12:37 PM
Experienced Mechanic
Good morning.
Did you verify power to the injector? I would do that with a test light or voltmeter first.
I assume you mean it does not flash? Is that correct?
It could be the ecm that has failed or it could be wiring to the ECM.
Sep 1, 2018 at 10:40 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
