injectors no power
211,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
AWR459
  • 8 POSTS
has fuel in fuel rail but no power to injector connectors.run if put gas in throttle opening.
Jan 31, 2016 at 12:28 AM
WRENCHTECH
  • 20,758 POSTS
The injectors are powered directly from the ignition switch on the white with red wire that turns into black and orange at the switch.
Jan 31, 2016 at 1:15 AM
AWR459
  • 8 POSTS
so saying switch bad?
Jan 31, 2016 at 2:01 AM
AWR459
  • 8 POSTS
How so cause put gas in throttle it starts.
Jan 31, 2016 at 2:04 AM
WRENCHTECH
  • 20,758 POSTS
Nobody said the switch was bad. Somebody needs to do some diagnostic work and I told you where to look.
Jan 31, 2016 at 2:13 AM
AWR459
  • 8 POSTS
I will check that tomorrow.
Jan 31, 2016 at 2:22 AM
AWR459
  • 8 POSTS
So am I checking to see if there's power at this white/red wire?
Jan 31, 2016 at 12:18 PM
WRENCHTECH
  • 20,758 POSTS
Isn't that how you determined there was no power to the injectors in the first place?
Jan 31, 2016 at 5:57 PM
AWR459
  • 8 POSTS
Thanks cause I'm lost when comes to wiring.Did find they was melted together.
Feb 1, 2016 at 12:12 AM
AWR459
  • 8 POSTS
Have battery power to 4 bigger wires there?
Feb 1, 2016 at 3:45 AM
WRENCHTECH
  • 20,758 POSTS
You found melted wires, then you need an electrical to sort this out for you.
Feb 1, 2016 at 4:04 AM
AWR459
  • 8 POSTS
I fix wires.still nothining there.
Feb 1, 2016 at 5:22 AM
  • 55,781 POSTS
Hi AWR459,
Did you check the fuses after the wires were fixed?
Apr 23, 2016 at 12:19 PM
