Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Fuel System
Fuel Injector
injectors no power
1992 TOYOTA CAMRY
211,000 MILES • 2.2L • 4 CYL • FWD • AUTOMATIC
AWR459
MEMBER
has fuel in fuel rail but no power to injector connectors.run if put gas in throttle opening.
Jan 31, 2016 at 12:28 AM
WRENCHTECH
Experienced Mechanic
The injectors are powered directly from the ignition switch on the white with red wire that turns into black and orange at the switch.
Jan 31, 2016 at 1:15 AM
AWR459
MEMBER
so saying switch bad?
Jan 31, 2016 at 2:01 AM
AWR459
MEMBER
How so cause put gas in throttle it starts.
Jan 31, 2016 at 2:04 AM
WRENCHTECH
Nobody said the switch was bad. Somebody needs to do some diagnostic work and I told you where to look.
Jan 31, 2016 at 2:13 AM
AWR459
MEMBER
I will check that tomorrow.
Jan 31, 2016 at 2:22 AM
AWR459
MEMBER
So am I checking to see if there's power at this white/red wire?
Jan 31, 2016 at 12:18 PM
WRENCHTECH
Isn't that how you determined there was no power to the injectors in the first place?
Jan 31, 2016 at 5:57 PM
AWR459
MEMBER
Thanks cause I'm lost when comes to wiring.Did find they was melted together.
Feb 1, 2016 at 12:12 AM
AWR459
MEMBER
Have battery power to 4 bigger wires there?
Feb 1, 2016 at 3:45 AM
WRENCHTECH
You found melted wires, then you need an electrical to sort this out for you.
Feb 1, 2016 at 4:04 AM
AWR459
MEMBER
I fix wires.still nothining there.
Feb 1, 2016 at 5:22 AM
Hi AWR459,
Did you check the fuses after the wires were fixed?
Apr 23, 2016 at 12:19 PM
Add image or video
Ask a new question
Engine won't start
Check engine light
