Injectors
120,000 MILES • 1.0L • 4 CYL • FWD • AUTOMATIC
PATROLR705
My car cannot start only when i spray inside the intake air cleaner. It runs for a while then for about five seconds then off. Fuel is working okay, i just replace pump.
Please can you advice me the cause of this problem?
Oct 12, 2017 at 10:33 PM
  • 31,937 POSTS
Do you have injection pulse at the fuel injectors? if you do not have a noid light to test the electrical impulse. often you can hear the injector click as the engine is turned over on the key.
Oct 12, 2017 at 10:51 PM
PATROLR705
Thank you for your reply. i believe there is no pulse because i did not hear any clicking sound.
Oct 13, 2017 at 5:29 AM
  • 31,937 POSTS
First thing to do is a scan, need to know what if any codes are set at this time.
Oct 13, 2017 at 8:41 AM
