Injectors
97 MILES
SUGARBUZZER
Hi, just wondering three injectors are very bad in my car. I was driving today and it started making a lot of noises i pulled in and turned it off and it stayed running for a few seconds. i drove again for a bit and now it will not start at all. i tried bleeding the injectors and no diesel is coming out? It is a Zetec S 130 and i was wondering can 2.2 st injectors fit and work instead of the ones i have in it? Could it also be that i have a bad injector pump that there is no diesel getting to them? Any help would be great thanks.
May 5, 2016 at 11:59 AM
  • 31,937 POSTS
You will have to get the fuel pressure tested, this can be done at a dealer with a factory scan tool, you can see a graph for fuel pressure desired and actual, you may have a failed high pressure pump.
May 5, 2016 at 7:34 PM
