Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Mercedes Benz
Vito
Engine
Wiring
Injector wiring test
2001 MERCEDES BENZ VITO
200,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
PETER DEKKER
MEMBER
Can the common rail injector wiring be tested with a lamp as with petrol fuel injectors?
Aug 8, 2019 at 9:52 PM
Experienced Mechanic
Yep, it sure can. here is a guide to help you test for the problem:
Aug 10, 2019 at 7:08 AM
PETER DEKKER
MEMBER
It is a diesel common rail system, that link is for petrol..
Aug 10, 2019 at 5:55 PM
Yes should still be the same this guide should help.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Aug 12, 2019 at 4:06 AM
PETER DEKKER
MEMBER
ok, can i use a 12v bulb as test light?
Aug 12, 2019 at 5:11 AM
Not really because the impedance is to high I would use a test light.
Aug 13, 2019 at 2:15 AM
Add image or video
Ask a new question
Engine won't start
Engine — Revs Up
