Injector problem
140,000 MILES • 1.6L • 4 CYL • 2WD • MANUAL
RENATO MOSTERT
Hi, i'm having injector problems injector 1.2.3 are dead however injector 4 appears to be stuck open when i just switch on vehicle it fires others are not working! I replaced them but still same problem. Checked all sensors as well as wiring they too are fine. any help please i'm far from diagnostic tools. please!
Jun 26, 2020 at 1:06 AM
  • 110,248 POSTS
I would be happy to help. I need to know the correct engine size. It should be a 1.8T, 2.0L, 2.8L, or a 1.9L diesel.
Let me know. Also, let me know if you have checked body grounds around the PCM and engine compartment.
Jun 26, 2020 at 12:57 PM
RENATO MOSTERT
Hi Joe,
Unfortunately its not a diesel vehicle it is gasoline and it has a 1.6lt engine . All ground wires i have cleaned and none have any damage.
Regards,
Renato
Jun 26, 2020 at 4:31 PM
  • 110,248 POSTS
Okay, this must be one for a different location and not offered in the US. But lets try something. Since I don't have info on the 1.6L, I will need you to trace the wire from the injector to the power-train control module. At that point, back probe the wire and see if there is an injector pulse.
I am basing this on the idea that all sensors are good as mentioned.
Jun 27, 2020 at 1:48 PM
STEVE W.
  • 15,411 POSTS
If the single injector is shorted on and the others appear dead but changing the injectors didn't help I would think the injector driver FET inside the engine control module has failed and is shorted. That would turn on that injector when the key comes on but the others wouldn't work.
A 2004 would likely be known as the VW Bora in other countries, Jetta is the north american and South African name.
Jun 27, 2020 at 2:03 PM
