Injector not working
187,916 MILES • 0.6L • 4 CYL • 4WD • MANUAL
PAT.2
  • 25 POSTS
My injector number two not working. I have changed it but still same issue.
Dec 27, 2018 at 10:01 PM
Good afternoon.
Did you verify power to the injector. with the key on, remove the connector and test for voltage at the connector.
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
the other wire goes to the pcm. that controls turning the injector on and off by grounding that wire. A tool called a noid light can confirm if it is doing its job. you can get one at the parts store.
Dec 28, 2018 at 3:44 AM
PAT.2
  • 25 POSTS
I had done that and even swapped the number one injector to number two, but still the same. I had changed the cylinder head valves at that side but still same issue.
Dec 28, 2018 at 3:57 PM
Have already done what?
What were the results? did you have voltage? did the noid light flash with the engine running?
need specific information to help you.
Dec 28, 2018 at 9:00 PM
PAT.2
  • 25 POSTS
Yeah the noid light flash please...
Dec 28, 2018 at 9:09 PM
Then the injector is working.
What is the original issue that made you think the injector was bad?
Dec 28, 2018 at 9:18 PM
PAT.2
  • 25 POSTS
I think misfire can cause this.
Dec 28, 2018 at 10:47 PM
yes, there is a lot more to a misfire than the injector.
you need to check compression in the cylinder, check for vacuum leaks and also check the ignition parts such as coil and plug.
Dec 28, 2018 at 10:51 PM
PAT.2
  • 25 POSTS
Have checked vacuum leaks, coil and plug as well. i think there is damaged cylinder in that side.
Dec 28, 2018 at 11:35 PM
yep, the compression?
Dec 28, 2018 at 11:41 PM
PAT.2
  • 25 POSTS
Why don't give me your phone number or your whatsApp number so that we talk directly.
Dec 29, 2018 at 12:02 AM
RENEE L
  • 1,260 POSTS
Hello, sorry our experts do not give out there private contact information. Please keep responding to this thread as it may help others as well.
Thank you,
Renee
Admin
Dec 30, 2018 at 10:53 AM
PAT.2
  • 25 POSTS
Okay thanks. i think is misfire that causing this so I am going to remove the cylinder head and base pan to check the piston rings and see.
Dec 30, 2018 at 3:35 PM
I would do a compression test first to be sure it is an internal issue.
Dec 30, 2018 at 7:56 PM
PAT.2
  • 25 POSTS
For now I have done everything on that car but still injector 2 not function. when you removed coil wire on the plug while the engine is running you can see the engine is shaking unless you insert the plug wire on the plug, but the number 2 didn't shake.
Jan 4, 2019 at 5:02 AM
You need to do a compression test as I suggested two times.
Jan 4, 2019 at 5:05 AM
PAT.2
  • 25 POSTS
What's mean by compression?
Jan 4, 2019 at 5:53 AM
The cylinder builds compression for the fuel/air mixture and when spark happens the mixture blows up and forces the piston down.
Jan 4, 2019 at 5:55 AM
PAT.2
  • 25 POSTS
We have changed all the piston rings too.
Jan 4, 2019 at 6:00 AM
No, that is not it. compression check the valves and the head gasket as well.
You should take this to someone to do this test for you since you have no idea of what it does and how to check it.
Jan 4, 2019 at 6:04 AM
PAT.2
  • 25 POSTS
Have already done all, have checked the valves and there was no leakage and I had changed the head gasket as well..
Jan 4, 2019 at 6:11 AM
you are not understanding what I am telling you, you need to have the compression tested.
Jan 4, 2019 at 6:14 AM
PAT.2
  • 25 POSTS
You are saying the compression I should check the valves and the head gasket isn't it?
Jan 4, 2019 at 6:22 AM
No, again, you do not understand. you need to take this to someone to check it for you.
Jan 4, 2019 at 6:23 AM
PAT.2
  • 25 POSTS
Okay thanks for your effort. which country are you from?
Jan 4, 2019 at 6:29 AM
USA
Jan 4, 2019 at 6:30 AM
PAT.2
  • 25 POSTS
Oh nice for meeting you. the reason why am finding difficult to solve the problem is that don't know much on Korea, Japan cars. I am only American cars engineer like; Ford Escape, Explorer, Fusion, Expedition, Lincoln and the red. so am happy to meet you guys.
Jan 4, 2019 at 6:35 AM
PAT.2
  • 25 POSTS
If I need Ford Explorer 2007 complete chain guards. can you guys please send some to me? because we find it difficult to get some here in Ghana.
Jan 4, 2019 at 6:42 AM
you are welcome.
Glad to help.
yes, we can.
Just open a new question on the site and one of us will be glad to help.
Jan 4, 2019 at 6:57 AM
PAT.2
  • 25 POSTS
How much do Ford Explorer 2008 control board cost and how can you help me to get it?
Jan 4, 2019 at 4:03 PM
Good morning Pat,
You need to start a new question.
The admins want a new question when we go to another vehicle and problem.
www.2carpros.com/question
I would be happy to help you find the part.
Jan 4, 2019 at 7:35 PM
PAT.2
  • 25 POSTS
Okay, thanks.
Jan 4, 2019 at 10:44 PM
You are welcome.
We are always glad to help.
Jan 4, 2019 at 10:48 PM
PAT.2
  • 25 POSTS
I am mechanic and am working on the vehicle listed above right now, the injector two is not working. I have swapped the number one injector to number two, but still the same. I had even changed the cylinder he's valves but still the same issue. the timing too is well fixed. the coil and the coil wires too working good. so what do you think is the cause of this problem?
Nov 26, 2020 at 12:16 AM (Merged)
  • 110,248 POSTS
If the problem remains at injector two regardless of switching the injector, you need to start by checking if there is an injector pulse to the number two injector.
Here is a link that shows how to check. If you have a noid light, use it to see if there is power to the injector.
If there is no power, then you need to trace the wiring back to the PCM to determine if there is a corrosion issue, the pin is pushed in on the connector, the wiring to it is bad, or if the PCM has failed.
Let me know what you find.
JOe
PAT.2
  • 25 POSTS
There is power coming on the injector. please
  • 110,248 POSTS
All I show is a 2.0L as the smallest for this vehicle. If you have power to the injector and it and a different one doesn't work, then it has to be a bad ground. Have you checked for grounding issues?
