After I change ignition coils RPMs do not go past 300?
116 MILES • 3.2L • 4WD • AUTOMATIC
JVONWISE5
The car doesn’t run unless I give it gas?
Sep 16, 2022 at 11:22 AM
  • 55,628 POSTS
It must be something wrong with a connector not being plugged in. Please go over your work again and if everything looks okay let's run the codes. Please check out this guide and get back to me. You can get a CAN scanner (Controller Area Network) from Amazon for about $36.00.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Here is a scanner link:
https://amzn.to/3eCqWWw
Sep 17, 2022 at 3:12 AM
