Will not start if the engine is warm
140,000 MILES • V8
GEBELB
1. When the engine is hot and I turn it off, it will not start up again until it cools.
2. If I don't start it every day, it starts very hard and it's 50/50 if the battery will hold out until it does start.
It has a 390 with a manual choke.
Jan 29, 2019 at 2:12 PM
Good morning,
When it will not start, do you have spark at the plugs?
It sounds like a failed ignition coil. It may not be delivering spark when it warms up.
Make sure there is fuel in the carburetor as well.
Jan 29, 2019 at 7:56 PM
