Engine running hot
125,000 MILES • 4 CYL • TURBO • 2WD • AUTOMATIC
JEWELZ169
Temperature gage registers normal although I can hear something bubbling after a 30 minute or so drive.
Feb 28, 2022 at 1:02 AM
SQM
  • 6,383 POSTS
Typically, the gurgling or bubbling noise is due to air trapped in the coolant system.
It can also be due to a leak that is allowing air into the sealed system.
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
Have you checked your coolant level? You want to make sure that the coolant is at the correct level and there is no leak.
Take a look at this helpful guide:
https://www.2carpros.com/articles/vehicle-bubbling-noise
Feb 28, 2022 at 4:33 AM
