Infotainment system not working?
125,000 MILES • 3.5L • V6 • 2WD • AUTOMATIC
JOELUND729
The radio in my vehicle is not working as well as the display screen, the screen will cycle on and off every five seconds only displaying a black screen. However, the backup camera will come on when in reverse but will again cycle on and off every five seconds. I have already checked the fuses and no luck??
Apr 13, 2023 at 11:11 PM
  • 110,248 POSTS
Chances are the software needs updates. You could contact a Nissan dealer to see if there are any notice, they have specific to this issue.
I was able to find several updates for the software.
Next, if the dealer is unable to provide help, what I recommend is to have the can-bus scanned for diagnostic trouble codes.
CAN stands for controller area network. Basically, the different modules in the vehicle are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing the codes. This is what I would suggest.
Here is a link that shows how it's done:
Because of the complexity of this system, the scan is where I would recommend starting unless there is a software update available.
Apr 14, 2023 at 1:37 PM
