Torque spec for camshaft bearing caps on 1G-FE needed?
290,000 MILES • 2.0L • 6 CYL • 2WD • MANUAL
BROKEN IS200
I have had to replace my valve stem seals in my IS200 and I'm now putting it back together, however i can't seem to find any torque specs for the camshaft bearing caps and was wondering if anyone could help me out.
Jan 8, 2023 at 2:34 PM
BORIS K
  • 836 POSTS
The camshaft bearing caps for the 1G-FE engine should be tightened to 15Nm.
Keep in mind that the bearing caps are marked I for intake and E for exhaust camshaft
Always apply a light coating of clean engine oil before fitting the caps.
Hope this helps.
Cheers, Boris
Jan 8, 2023 at 5:37 PM
