Good afternoon, first of all I want to thank you for your time.
The first symptoms I have experienced were when hitting speed over 60 MPH it wouldn’t shift gears to speed up, but RPM would keep climbing. Another symptom is when coming to a sudden stop, if I accelerate suddenly the car shakes before speeding up.
I have a P1757 code saying Front Brake solenoid. My question to you would be, what is the best approach to this repair? I have been searching for a donor transmission from the same vehicle but no clue if it will work as simple as a swap. My other option would be opening the valve body and soldering on the connections then put it all back together.
Thank you
Thank you
May 23, 2023 at 12:31 PM
