1999 Infiniti QX RADIATOR REPLACEMENT
1999 INFINITI QX
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHRIS LOVELY
THE TWO TRANNY LINES THAT RUN INTO THE RADIATOR,ONCE YOU REPLACE THE RADIATOR AND PUT THE TRANNY LINES BACK ON WHAT IS THE METHOD OF FILLING THE RADIATOR,DOU YOU NEED TO PUT ANY OTHER FLUID OTHER THAN ENGINE COOLANT,ALSO HOW DO YOU DRAIN THE BLOCK OF COOLANT IF NESSESARY?THANKS FOR YOUR TIME CHRIS
Dec 31, 2008 at 6:34 PM
BLUELIGHTNIN6
  • 16,542 POSTS
engine block should have a plug on it to drain. the radiator is filled with the proper coolant mix, the same coolant cools the tranny as well so no other fluids are needed in the radiator.
Apr 23, 2010 at 12:01 PM
