1999 Infiniti QX fuel system
1999 INFINITI QX
153,000 MILES • 6 CYL • 4WD • AUTOMATIC
SHAUNTAY911
I have a qx4 w/ a 3.3 liter v6. I just had the timing belt water pump and cam seals replaced at the nissan dealership. About 3 days later the truck died right after filling up with gas. It will not start and acts like its not getting fuel, the starter is cranking. I haven't replaced the fuel filter since I've owned it so I did that and checked fuses and relays. It still won't start. I was thinking it might need a fuel pump but then I read that it could be the fuel pressure regulator. I would like to fix it myself if I can and was going to start with the regulator but I don't know where it is located and if that is my best option.
Apr 27, 2009 at 2:24 AM
Lets verify which one is missing do below and comeback and tell me what's missing we start here
Get helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Apr 27, 2009 at 2:40 AM
