2002 Infiniti Q45 engine light on
115,000 MILES • V8 • 2WD • AUTOMATIC
JAEMS
2 days ago the engine service light came on and i took it to auto zone for a free code reading it said there was a large vaccuum leak possible. how do i know where the vaccuums are and how many are there.?? thanks for the great site
Mar 11, 2010 at 11:39 AM
LEGITIMATE007
  • 5,121 POSTS
one trick that we use to figure this out is first try and listen carefully for a hissing or whistling sound, if nothing comes of that, then, take some brake kleen(thats how its spelled) and gently spray it around all the hoses and intake, if you hear a change in idol, then that is where your leak is. concentrate mostly around the back side of the engine towards the firewall and the brake booster, you prbably have a partially connected hose thats causing the leak
Mar 11, 2010 at 12:42 PM
