1997 Infiniti Q45 Won't Start Problem
180,154 MILES • V8 • 2WD • AUTOMATIC
1BIGBEN
I tried to start the car today after pulling it in last night. It cranks but not close to starting and it always starts quick and easy. I changed the fuel filter as it had been 30,000 kiles since it was done last but it did not start after this effort. I plugged in my scan tool and read no codes.
Any ideas?
Mar 15, 2010 at 10:30 AM
  • 75,988 POSTS
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 15, 2010 at 11:12 AM
