1997 Infiniti Q45 Runs real bad.
1997 INFINITI Q45
170,000 MILES • V8 • 2WD • AUTOMATIC
MR.MORENP
I had a misfire and changed the spark plugs along with the valve cover gaskets due to oil found in the cylinders. It was running rough before the the spark plugs were changed. After the the test drive it took off like a champ. After a while it started doing the same thing as before so I turned around a went back home. About 1 mile from my house the car started to sputter and lose all power. I made it home, and somke started coming up from under the hood. Opened the hood and saw the catalytic converter glowing red. The next day I removed the cat and drove it to see if I had a bad cat. Same thing happened. It took off good, but this time it started sputtering and losing power sooner. When I got to a red light the car turned off. I started it back up and made if home. The car still starts, i just haven't driven it since then. It's been sitting for about 3 days now. Can you please point me in the right direction.
Jun 16, 2008 at 9:46 PM
KHLOW2008
  • 41,814 POSTS
Hi Mr.Morenp,
If the catalytic converter is running red hot, one of the cylinder is not working.
Check for a bad plug, coil or cylinder compression.
Jun 22, 2008 at 11:26 AM
