1996 Infiniti Q45 bucking and stalling
1996 INFINITI Q45
14,300 MILES • V8 • 2WD • AUTOMATIC
DEREK JARVIS
I have a 1996 Q 45 and am having a problem with bucking and then stalling while driving.
The car run perfectly for about a half hour and then it will stall at red lights or worse when you are moving.
I'm thinking a MAF sensor but why does it run ok until it heats up?
Any suggestions?
May 17, 2009 at 1:39 PM
DOCFIXIT
  • CAR REPAIR CONTRIBUTOR
  • 18,828 POSTS
Hi
More inclined to suspect crankshaft and/or camshaft sensors. Check engine light on? Tune up recent, filters etc.?
Let me know
Thanks for donate
May 18, 2009 at 11:57 AM
DEREK JARVIS
The check engine light does come on. I have a new air filter in the car. Haven't had a tune up in a while.
How expensive are these sensors you mentioned and how do you check for them being bad?
Cheers Derek
May 19, 2009 at 9:49 AM
DOCFIXIT
  • 18,828 POSTS
Need to have codes read from computer that will give clue as to what is happening. Can you do that and post will advise.
May 19, 2009 at 10:00 AM
UPENZI
I had this EXACT same problem with my 94 Q45. I took it to a mechanic who replaced the MAF Sensor and the problem has been gone ever sense. You can get one online for about $100. Or you can have a mechanic order it since they get a discount and it'll cost about $70.
I got mine done for free since the dealer I got my car from had a 30 day warranty.
Aug 16, 2009 at 12:10 PM
