1995 Infiniti Q45 reverse
200,000 MILES • V8 • 2WD • AUTOMATIC
DOUGT
Backed out of driveway fine, next time for reverse, no go. all other selections work fine. no fluid damage, no leaks, no noise. Release button on shift lever does not pop up when in reverse. Is that normal? Have not noticed, but pops up in all other selections.
Jul 4, 2008 at 3:17 AM
KHLOW2008
  • 41,812 POSTS
Hi DougT,
Button should pop up in all gears.
If the reverse is not working, it could be trouble with the trans and not the shift lever.
Jul 5, 2008 at 2:28 AM
DOUGT
pulled the pan, found metal shavings on magnet, something came loose. will be replacing transmission. No easy fix for this problem.
Jul 7, 2008 at 6:25 PM
KHLOW2008
  • 41,812 POSTS
Hi DougT,
Too bad the trans decided to call it a day.
Yup, it would be costly too.
Jul 8, 2008 at 12:25 AM
