1992 Infiniti Q45 Break lights will not come on!
1992 INFINITI Q45
199,000 MILES • V8 • 2WD • AUTOMATIC
CR08VR
right and left brake lights not working. brake light in rear window works fine. I have checked all fuses for possible problems. they look fine
On Jan, 7th of 09 chaddrew89
asked you this same question, this seems like an issue common with these cars. I never read that anygave him an answer though???? please help.
Mar 15, 2010 at 8:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
hello and thanks for donating
if you have checked wiring, bulbs and fuse(s) for rear brake lamps then that leaves the brake lamp switch which is located near brake pedal below driver side dash.
Mar 15, 2010 at 8:28 AM
