1991 Infiniti Q45 Oil Light and Pinging
INFINITI
J.MITCHELL_985
1991 Infiniti Q45. 121,000miles. I experiencing pinging noise and the oil light is flashing on and off. I had a partial oil change (change the oil but not the filter). Could that be a problem or more? I haven't drove it much since the problem.
Aug 16, 2007 at 6:00 PM
  • 75,988 POSTS
[quote:8fdb7b08b4="j.mitchell_985"]1991 Infiniti Q45. 121,000miles. I experiencing pinging noise and the oil light is flashing on and off. I had a partial oil change (change the oil but not the filter). Could that be a problem or more? I haven't drove it much since the problem.[/quote:8fdb7b08b4]
Clogged oil filter-the oil will not circulate and with a bad oil pump the oil won't go no where-the pinging could be a bearing/s knocking.
Get an oil pressure gauge-find the sending unit remove it and hook the gauge up and read the oil pressure. Then report back your findings
Aug 16, 2007 at 7:04 PM
Suggested Repair
Do not drive the car until oil pressure is verified. Install a mechanical oil pressure gauge at the sending unit and read the pressure. A clogged oil filter or failing oil pump can stop oil circulation, and the pinging may be bearing knock.
Conversation Summary
The owner of a 1991 Infiniti Q45 with 121,000 miles reports pinging and a flashing oil light after changing the oil but not the filter, and has driven the car little since. The expert says a clogged filter or bad oil pump can prevent oil circulation and that the noise may be bearing knock. They recommend hooking an oil pressure gauge to the sending unit and reporting the reading.
