Infiniti Other
INFINITI
HEVNLAND
ok i just changed the head gasket on my 95 - g20 and i believe the timing is aligned right, but i still have low compression on cyl. 1-3 and #4 reads twice as much ... 1-3 pressure is 25 lbs. psi-- and # 4 is 50 lbs. psi...
i know i torqued the head down right, would missed timing effect compression? if not what else could it be?
Oct 22, 2007 at 7:28 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds l like you missed the cam timing.Try the "repair manuals" link at bottom of forum main page. There you will find a diagram of what should be aligned where to make it run again
Oct 22, 2007 at 7:43 AM
