1995 Infiniti G20 Low Compression
INFINITI
HEVNLAND
ok i just changed the head gasket on my 95 - g20 and i believe the timing is aligned right, but i still have low compression on cyl. 1-3 and #4 reads twice as much ... 1-3 pressure is 25 lbs. psi-- and # 4 is 50 lbs. psi...
i know i torqued the head down right, would missed timing effect compression? if not what else could it be?
Oct 22, 2007 at 7:28 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds l like you missed the cam timing.Try the "repair manuals" link at bottom of forum main page. There you will find a diagram of what should be aligned where to make it run again
Oct 22, 2007 at 7:43 AM
Suggested Repair
Recheck cam timing against the repair manual alignment diagram and correct any missed cam timing before further diagnosis.
Conversation Summary
The owner of a 1995 Infiniti G20 replaced the head gasket and reports about 25 psi on cylinders 1-3 and about 50 psi on cylinder 4, despite believing the timing is aligned and the head was torqued correctly. They asked whether missed timing can cause low compression. The expert said the cam timing was likely missed and recommended the repair manual diagram for correct alignment.
