1993 Other Infiniti Models pressure build up
1993 INFINITI
16,500 MILES • 6 CYL • 2WD • AUTOMATIC
RUFFGUT
air works fine for couple of weeks then compressor kicks on and off.check pressure with gauge and has 80 lbs.let pressure out mashing valve on lp side down to 40 to 45 lbs seems to be all air and oil. works fine for 2 to 3 weeks then repeats cycle.
Jun 5, 2008 at 8:37 AM
MERLIN2021
  • 17,250 POSTS
Check the sytem with a good set of manifold gauges, high side 200 low 40, watch for any bouncing of the needles...report findings.
Jun 5, 2008 at 8:50 AM
