2003 Infiniti M45
114,000 MILES • V8 • FWD • AUTOMATIC
CYNTHIAED
WHILE DRIVING EITHER AT 45 MPH OR 70 MPH MY RPM DROPPED FROM 2000 OR SO TO ZERO. THE FIRST TIME IT WAS AT 45 MPH AND THE SPEEDOMETER DID NOT VARY...LAST TIME WSA AT 70 MPH AND THE SPEEDOMETER DECREASED TO APPROX 30 MPH THEN THE CAR SHUT OFF.....IT WOULD NOT START BACK UP RIGHT AWAY BUT AFTER 5 MINS OR SO IT STARTED RIGHT BACK UP WITHOUT MUCH OF A PROBLEM....NO CHECK ENGINE LIGHT DURING THE INCIDENT OR AFTER
PLEASE HELP.....INFINITI DEALERS SAY THAT THEY CAN NOT FIQURE OUT W/O CHECK ENGINE LIGHT BEING ON....
Jul 18, 2008 at 5:14 PM
  • 31,937 POSTS
Hi there,
I would start with a scan, as the check light will not always be set when a fault is detected by the ECU. Start here.
mark (mhpautos)
Jul 18, 2008 at 5:31 PM
CYNTHIAED
Thank you for your help.....however what is an ECU...the same as an ECM.
Jul 18, 2008 at 5:46 PM
  • 31,937 POSTS
Hi there,
Yes, sorry in Aust we call it the ECU (engine control unit)
Mark (mhpautos)
Jul 18, 2008 at 6:03 PM
