front crankshaft seal replacement?
185,000 MILES • 6 CYL • 2WD • AUTOMATIC
DKANG
need procedure for front crankshaft seal replacement
Sep 17, 2009 at 10:03 AM
SQM
  • 6,383 POSTS
In order to replace the front crankshaft seal you will first have to remove the drive belt.
Then the crankshaft pulley needs to be removed.
That will give you access to the seal. Which can be removed using a seal remover tool.
You might find this article helpful:
https://www.2carpros.com/articles/front-main-seal-replacement
I have attached diagram for your reference.
Sep 21, 2021 at 2:47 PM
