1996 Infiniti J30 headlight
KAY WILKERSON
Electrical problem
1996 Infiniti J30 6 cyl Two Wheel Drive Automatic 140k miles
headlight on passenger side comes on and goes off both bulbs bright and dim are good. They work for a few minutes and go off.
May 6, 2009 at 12:39 PM
JOHN REED
I had this exact same problem. The passanger lights would go out randomly. The dealer said ist was the switch. I thought it was a relay. I was right. After paying for a switch & still having the problem, I had to pay for a relay. bummer. It is located on the drivers side firewall. you can hear it click when the light goes on & off, if you are patient enough.
Bob Reed bob_reed_1@hotmail.com
Jul 8, 2009 at 9:02 AM
FRAJAGAMO69
  • 6 POSTS
hello, i has same problem with my infiniti just take off and put back the headlamps fuses located on passenger side fire wall fix it
Oct 4, 2010 at 3:28 PM
