1995 Infiniti J30
1995 INFINITI J30
189,368 MILES • 6 CYL • 2WD • AUTOMATIC
SAMUEL.GREEN
Engine starts; idles OK will not accelerate.
Jun 9, 2010 at 11:39 PM
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Jun 10, 2010 at 9:44 PM
