1994 Infiniti J30 Emergency Brake Release
1994 INFINITI J30
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
ALICE TANG
Emergency brake release handle broke off . Is there an easy way I can release the brake from under the hood? Can't drive to the mechanic's. Can't be towed?
Jul 14, 2010 at 12:26 PM
BLUELIGHTNIN6
  • CAR REPAIR CONTRIBUTOR
  • 16,542 POSTS
Best ways are if you can see exposed cable underneath the truck, go underneath and yank down on the cable as hard as you can. If the parking brake isnt needed or you just need to free the brake to move the truck and can go get it repaired if necessary, cut the cable back by the brake and the brake will release. Shouldnt cost more that 150 bucks to get a new e-brake installed.
Jul 14, 2010 at 1:14 PM
