After installing a transmission filter and changing out the differential fluid, we cannot get the car to move when it is in gear and we also wanted to change out the fluid from the trq. converter so we un hooked the positive pressure side to the transmission cooler and no fluid is coming out.
The replacement filter did not fit as snug as the other filter that I took off but it worked. I don't think that any fluid is getting circulated in the transmission, thus the car is not moving.
I plan on putting back in the old filter and seeing if that will make a difference. I don't think any serious transmission damaged has occurred but if I could be re assured that would be great.
thanks!
thanks!
May 29, 2010 at 7:13 AM
