1999 Infinity QX4 Catalytic Converter/Exhaust Manifold Join
1999 INFINITI QX60 HYBRID
236,000 MILES • 6 CYL • 4WD • AUTOMATIC
LASERJOE100
Just changed both exhaust manifolds, and front pipes.
The joint between the cat converters and the manifolds
both leak badly, even with new converter caps and wire washers. BAD!! Now I'm told that the cat converters should have been changed at the same time because it's impossible to get a good seal between the new Manifolds and the old CC's.... True? Too late to change the cats now since the manifolds have already been run hot, so....??
Aug 6, 2010 at 2:21 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
Are these a flat flange type bolt up system?
Mark (mhpautos)
Aug 6, 2010 at 5:22 PM
LASERJOE100
Yup.... Flange with a lip that interlocks with the manifold. There is also a "wire washer", and a cap, which is a hollow ring that covers the wire washer, that act similar to giant "o" rings within the cats.... Leaking like heck!!
The theory was that because the manifolds are new, and the cats are old, they may not ever be able to seal because the did not warp together... But that doesn't seem right to me, because that would mean that every time a manifold got changed, the cat would have to change, too....
Aug 6, 2010 at 5:42 PM
  • 31,937 POSTS
I would be thinking the flange on the cat is warped from manufacturer, i have seen this a few times, check with a straight edge.
mark (mhpautos)
Aug 7, 2010 at 12:15 AM
LASERJOE100
That's probably not the case, since BOTH manifold/cat connections are leaking. In any case, the mechanic is claiming that the cats (not replaced) and the manifolds (new) would never give a perfect seal simply because the old cats would be slightly warped just due to regular use. That doesn't seem to me to make sense, since that would mean that one would ALWAYS have to replace cats along with manifolds to get a perfect seal...Besides, shouldn't the wire washer/caps take care of this by acting as a gasket?
The short question is: should I be able to get a tight seal using the old cats along with new manifolds? Is this a common problem?? Thnx.
Aug 7, 2010 at 12:42 AM
  • 31,937 POSTS
There should be no reason not to be able to get a gas tight seal with old cats and new manifolds.
mark (mhpautos)
Aug 7, 2010 at 12:50 AM
