My I35 lately seems to be running alittle hot while A/C is on in normal traffic according to the gauge on the dash. If I turn off the A/C and just run the Fan the temp drops slowly. If I turn on the heat the temp will go down to the normal range. If I return to A/C the temp will rise. Mind you that the temp is not rising to the overheat stage, just that the cooling fans are running pretty hard. What do you think is the problem?
Aug 2, 2010 at 6:24 AM
