2002 Infiniti I35 Steering Fluid Leak Suspected - What to d
2002 INFINITI I35
82,000 MILES • 6 CYL • 4WD • AUTOMATIC
JJEN612545
Steering wheel fluid needs to be replaced nearly twice a week and car whines loudly when fluid gets to half full level. What is cause and what should be done?
Aug 3, 2009 at 9:20 AM
  • 31,937 POSTS
Hi there,
You will have to locate this leak, the system is very basic only a pump on the engine the steering rack or box and a pressure hose and a return hose, with this leak just wash down and run the car turning the steerings, you should see the leak dripping, if in doubt get your mechanic to inspect this on a hoist as this will make things easier.
Mark (mhpautos)
Aug 3, 2009 at 10:09 AM
