2002 Infiniti I35 heater fan problems
117,000 MILES • 6 CYL • FWD • AUTOMATIC
ROSS BALLANTYNE
the heater fan is making lots of noise has been for some time it sounds like its geting ready to come to a stop now how ever asitis getting worse . can you tell mehow to change it out
Aug 6, 2010 at 10:45 AM
  • 75,988 POSTS
REMOVAL
https://images.2carpros.com/forum/automotive_pictures/12900_blower_1.gif
Discharge the A/C system. Disconnect the two refrigerant lines from the engine compartment. Cap the A/C lines to prevent moisture from entering the system. Remove the glove box and mating trim. Refer to "Instrument Panel Assembly". Disconnect the thermal amp. connector. Disconnect the intake sensor connector. Disconnect the fan control amp. and blower motor connector. Remove the blower and cooling unit. Separate the blower and cooling unit case, and remove the evaporator. Remove the three bolts and then remove the motor from the blower case. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Aug 6, 2010 at 11:41 PM
