Blower, fuses, and fan adjustment level is good. I only get .2 to .3 volts at the blower connector. under the dash.
Jun 8, 2010 at 1:17 PM
✓Experienced Mechanic
Test the blower motor resistor this is where it will drop the voltage before it gets to the blower motor-
Jun 8, 2010 at 1:20 PM
DOCC
MEMBER
Thanks , now where would that be. I know just a little about my daugther's car.
Jun 8, 2010 at 1:27 PM
Check it -disregard the blower motor resistor don't have one -check and test the fan controller amplifier behind right side of dash on blower and cooling unit-
Jun 8, 2010 at 1:41 PM
DOCC
MEMBER
do you have a picture of this amp. Because I did take apart the glove compartment and pulled the blower out. would this amp be inside the blower hole.
