2001 Infiniti I30 want idle
2001 INFINITI I30
83,000 MILES • 6 CYL • FWD • AUTOMATIC
ROCKYBALBOA
The car want idle in nuetral and has no power beyond 3k rpm's.
Dec 5, 2009 at 11:15 AM
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Dec 5, 2009 at 11:40 AM
