Car will not start. Replaced battery two days ago. Worked for a short time. Car quit last night. Checked alternator. Meter shows 13.9 loaded and 13.7 unloaded. Turn the key and all you hear is a loud "click" with no starter rotation. Attempted several times with no starter rotation, just the loud click.
Connected jumper cables from another car that was running. Turned key, starter turned and car started without trouble. Checked battery again and alternator again. Brand new battery checks ok. Alternator checks ok. What is wrong here? Is it the starter, the relay, or the ignition switch?
Stranded in Easton, MD.
Aug 21, 2008 at 10:15 PM
