2001 Infiniti I30 LEAKING
93,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARK MITCHAM
I have a 2001 Infiniti I30 that has just started leaking fluid from somewhere above the radiator. the fluid is red, there is a hose that runs accross the radiator that it looks like its coming from. Could there be a hose that need repairing that runs accross the the top of the radiator that would be leaking transmission fluid? And how should I go about repairing it. Its a small leak that I can only tell that is leaking when car is off.
Oct 4, 2010 at 9:40 AM
KHLOW2008
  • 41,812 POSTS
Hi Mark,
Transmission lines do not run across the radiator top. The line could be from the power steering system. Check where it connects to. If it is the pressure hose, it would leak when engine is started and steering turned.
Oct 5, 2010 at 7:54 AM
