2001 Infiniti I30 car hesitates when first started and taki
106,000 MILES • 6 CYL • FWD • AUTOMATIC
BROTUS_MIL
I have a 2001 Infiniti I30, 106000 miles. I had the regular services performed and am noticing the car hesitating when I first start and take off.After a minute it runs fine and has no more problems and rpms are fine and steady. I had the sparkplugs changed @99k. I tried pulling codes no luck, tried seafoam no luck, checked battery and hoses nothing. Any help is appreciated
Oct 23, 2010 at 10:46 AM
  • 75,988 POSTS
Lack of acceleration,chugging,hesitating,jerking,bogging,misfiring etc. could be caused by one of the following below
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Knock sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it
Oct 23, 2010 at 11:37 AM
