2001 Infiniti I30
HEATHERL
  • 2001 INFINITI I30
2001 Infiniti I30 6 cyl Automatic 110000 miles
I tried to put gas in my car and was unable to get it to go in. If I pumped it very slowly I could get a little in but it kept running backout of the tank. Its at a repair shop now. They have took the gas tank off and checked the hoses and found nothing. They were able to get about $7 in before it started running back out the tank again. Any ideas as to what could be causing this, there pretty much at a loss at the repair shop. Thanks
Tuesday, July 1st, 2008 AT 10:44 PM
KHLOW2008
  • 41,814 POSTS
Hi heatherl,
There is a smaller hose running parallel with the main fuel pipe, check if it is kinked or clogged.
It could be the main pipe ball/valve is stuck in the closed position.
Saturday, July 12th, 2008 AT 9:44 AM
