2000 Infiniti I30 spark plug coils
106,000 MILES • 6 CYL • FWD • AUTOMATIC
BAN2
My "check engine" lite is on so I took the car to a local parts dealer to determine the problem.
He said the code showed misfire on plug one and prob was the coil on this plug ( I didn't get the code # --sorry)
I replaced all the plugs about 15k mi ago
Question is -- can I replace just one plug coil?
Local Infinity dealer told me I had to replace them all and full tune up would be $over $900. !!!!
This is hard for be to believe.
thank you
May 17, 2010 at 12:58 AM
2CARPRO JACK
  • 11,533 POSTS
Sorry but it is true.If you replace just one coil, the code wont go away, worst part is that you have to use Nissan coils , otherwise even replacing all of them wont fix it.Im not sure of the exact reason, but I have personally been down this road, and tried just one coil and the car was back the next day.....replace the other 5 with Nissan coils and havent seen it since....(Knock on wood....LOL)
May 18, 2010 at 6:39 AM
BAN2
are replacing the coils something that can be done by self?
Have plenty of mech exp.
Is there any special adjustments or measurement sets that need to be made?
thanks
May 18, 2010 at 7:33 AM
2CARPRO JACK
  • 11,533 POSTS
I cant remember exactly if anything has to be removed to replace them,but I dont think so.Did a little checking on a Nissan site, and they claim the coils just unbolt and will come right out.Be sure you have Original Equipment plugs as well.
May 19, 2010 at 12:55 AM
96INFINITII30
  • 21 POSTS
Depending on if they are on the front or back (left or right) side of the engine. If they are on the front, you will need a small allen wrench and remove the Nissan or infiniti 3000 plate. Then unscrew the coil and replace. very easy.
I believe number one is on the back side of the motor. You will need to remove the intake manifold (intake plenum) to get at the coils. Kind of a pain but still do-able for the DIY person. Make sure you tighten the bolts on the intake in the proper order and to the right torque specs.
I replaced one coil, with a used coil, and reset the computer and never saw any code come back. Might happen, might not. Coils are only about 60-70 dollars at the local parts store. Although its a good idea to replace them all, you can replace just one.
Good luck.
Jun 3, 2010 at 8:25 AM
96INFINITII30
  • 21 POSTS
UPDATE: I misspoke when I said you will need to remove the intake manifold. You do NOT need to remove it. Removing the coils are very easy. It should be an 8mm screw. Remove screws take old coil out and replace.
[quote:097cf590b1="96Infinitii30"]Depending on if they are on the front or back (left or right) side of the engine. If they are on the front, you will need a small allen wrench and remove the Nissan or infiniti 3000 plate. Then unscrew the coil and replace. very easy.
pdftown.com/PDF-Infiniti-I30-2001-Service-Manual.html
Here is a link to a manual, they are very handy. Look through it and it should guide you through it. Good luck.[/quote:097cf590b1]
Jun 19, 2010 at 10:34 AM
2CARPRO JACK
  • 11,533 POSTS
Thx for the update, didnt think it had to come off
Jun 20, 2010 at 11:22 AM
