2000 Infiniti I30 Replacement of MAF sensor
214,000 MILES • 6 CYL • FWD • AUTOMATIC
VANDONKEYDICK1
Brought my car into the dealer, as it had a TCS-Slip lights on, and was running really rough. After diagnosis was done, it was found to have a miss on bank#1. Replaced all coils, and just replaced MAF sensor, as it was found to be the problem. It runs fine at normal speed, but fluctuates rpms at idle, and will intermittently stall. Wondering if the computer is trying to figure out the air fule mix, or if the sensor is bad, although brand new. Checked the harness, relay, replaced air cleaner, reset computer, still not right.
Nov 29, 2008 at 8:38 AM
BMRFIXIT
  • 19,053 POSTS
vacuum leaks
check intake manifold and gasket
Dec 13, 2008 at 7:39 AM
