2000 Infiniti I30 power steering fluid leaking behind right
2000 INFINITI I30
149,000 MILES • 6 CYL • 2WD • AUTOMATIC
GSKOC
leak appears to be in the actuator. How had will this be to replace for someone not mechanically sound?
Aug 2, 2009 at 11:47 AM
  • 31,937 POSTS
Hi there,
I would recommend that you get this done by a mechanic, you are dealing with the steering and if you make a mistake or over look something important this could be very dangerous, don't risk it as you say your are inexperienced so get a mechanic to do this job.
mark (mhpautos)
Aug 2, 2009 at 12:14 PM
