2000 Infiniti I30 Could this be a blown fuse?
2000 INFINITI I30
78,000 MILES • 6 CYL • FWD • AUTOMATIC
ILLINOISINFINITI130T
My traction control light is showing "off" and my moon roof will not open. There is no motor noise for the moon roof, and trying to switch the traction control button doesn't work. I suspect this is a fuse issue. Is it? And if so, how do I know which fuse needs replacement? The car starts and runs fine otherwise.
Thanks for your help!
Jul 11, 2008 at 4:29 AM
KHLOW2008
  • 41,814 POSTS
hi Illinoisinfiniti130t,
The best way to check fuses is with the aid of a test lamp.
Ground the test lamp and use the probe to test both ends of the fuse to be checked, if 1 side has power and the other does not, the fuse is blown.
Those that operates through the ignition switch must be tested with ignition switched on.
Jul 12, 2008 at 2:18 AM
