My ACC does not regulate the cabin temperature. I should be able to set it at room temperature, say 70F, and Automatic Climate Control should maintain that temperature. Instead only cold air blows unless I set the temperature control to the maximum. What needs to be replaced to cure this problem? Thanks
Nov 12, 2008 at 1:03 PM
