2000 Infiniti I30 Automatic Climate Control
HEF951
  • 2000 INFINITI I30
  • 6 CYL
  • FWD
  • 200,000 MILES
My ACC does not regulate the cabin temperature. I should be able to set it at room temperature, say 70F, and Automatic Climate Control should maintain that temperature. Instead only cold air blows unless I set the temperature control to the maximum. What needs to be replaced to cure this problem? Thanks
Wednesday, November 12th, 2008 AT 9:03 PM
DAVE426
I have the identical problem with my 1999 I-30 T, at 130,000 miles. If I find an answer, I'll let you know. Otherwise, I'll stay tuned for your reply.
Saturday, December 13th, 2008 AT 7:45 PM
HEF951
Temperature sensor inside dash sometimes stops working properly due to dust buildup. Mechanic blew compressed air into sensor vent and ACC now regulating temperature properly. If sensor stops working all together then it needs to be replaced. So far mine seems to be working.
Wednesday, December 17th, 2008 AT 2:20 PM
DAVE426
Thanx, hef. Glad to hear you got it fixed. I didn't get off so lucky. It sure was worth a try, though. Guess I'll go buy a sensor.
Wednesday, December 17th, 2008 AT 2:47 PM
