1999 Infiniti I30 How do I remove the back seats
1999 INFINITI I30
157,000 MILES • 6 CYL • FWD • AUTOMATIC
KATOLIVER2001
I believe I have a dead Mouse between my back seat and the trunk wall. Is there a trick to removing the back seats so that I can find out where that aweful dead mouse smell is coming from... Yuck!
Thanks for your help
Woman in distress... :)
Oct 3, 2010 at 12:23 PM
KHLOW2008
  • 41,814 POSTS
Hi katoliver2001,
You need to remove the rear seat cushion to get to the holding bolts of the rear seat rest.
To remove the seat cushion, check under the front portion of the seat for any holding clips that if pulled or pressed would release the seat.
After removing the cushion, you would see a bolt ion either side of the seat rest. Remove them and lift the seat upwards to dislodge it fron the locking tabs behind it.
Oct 5, 2010 at 8:02 AM
