1998 Infiniti I30 Crankshaft Sensor
141,500 MILES • 6 CYL • 2WD • AUTOMATIC
BERTKELL
The MIL Light is on and the DTC code is P1335 CKP Sensor (ref). Which sensor is this? Where is it located? and how do you replace it?
I am also starting to have problems starting the car.
Jan 7, 2008 at 2:46 AM
MERLIN2021
  • 17,250 POSTS
CKP= Crankshaft position sensor, if it's not sending a signal to the PCM, you will have a hard time! It's mounted down by the crank pulley, on the block...
Jan 7, 2008 at 6:08 AM
